rev 645 - crash - Character dialog box on Cancel click.
Post bug reports and suggestions here for the beta version of TextMaker 2012 for Windows.
ivan_h
Post by ivan_h » Wed Nov 16, 2011 12:24 pm
Create a new text document in TextMaker. You don't have to type anything.
Right click on the document, select "Character" from the context menu.
On the "Character" dialog box simply press the Cancel button to close it - TextMaker crashes.
XP SP3. Clean install. Virtual machine.
Neil_Parks
Re: rev 645 - crash - Character dialog box on Cancel click.
Post by Neil_Parks » Wed Nov 16, 2011 6:32 pm
Cannot replicate using buid 650-1110, XP Pro sp3.
"Program in haste; debug at leisure."
Post by sven-l » Thu Nov 17, 2011 9:58 am
This is also not reproducible for me. Please try to rename the folder settings in My Documents\SoftMaker (e.g. to "Settings_old") and try again.
JohnWasilewski
Post by JohnWasilewski » Thu Nov 17, 2011 12:41 pm
I have ver. 651.1113.
Following Ivan's instructions, I can't cause a crash.
John
ivan_h
Post by ivan_h » Thu Nov 17, 2011 1:45 pm
I see that all of you are using a newer revision. Is there a way to download the newer revision?
I've downloaded the 645 revision by following the main page link to here: http://www.softmaker.com/english/ofw12betareg_en.htm.
Post by sven-l » Fri Nov 18, 2011 8:55 am
The beta will only run for until end of November. I would suggest to download the new trial version instead, which includes a lot of bugfixes:
http://www.softmaker.net/down/ofw2012eval.exe
ivan_h
Post by ivan_h » Fri Nov 18, 2011 12:54 pm
Installed rev 650 using the link you provided.
The issue is resolved. Thank you.
Return to “Beta: TextMaker 2012 for Windows”
