Text Maaker 2010 opening instead of Textmaker 2012
Post bug reports and suggestions here for the beta version of TextMaker 2012 for Windows.
KA7AOK
Post by KA7AOK » Thu Oct 27, 2011 12:17 am
When I open TextMaker from the start panel, TextMaker 2010 opens instead of 2012. Both PlanMaker and Presentations open as 2012.
Re: Text Maaker 2010 opening instead of Textmaker 2012
Post by sven-l » Fri Oct 28, 2011 11:08 am
Please open TextMaker 2012 from the install folder (C:\Program files\SoftMaker Office 2012) and close it. Does the correct version now start from the start panel?
KA7AOK
Post by KA7AOK » Fri Oct 28, 2011 6:41 pm
Yes, it does. Thank you. :)
Azrael
Post by Azrael » Sat Oct 29, 2011 6:14 pm
The same problem and solution in a combination of Textmaker 2008 and 2012 beta (644)
Post by sven-l » Thu Nov 03, 2011 8:12 am
This is a normal behavior of the SMASH shortcut icons. It always starts the version you used at last.
Return to “Beta: TextMaker 2012 for Windows”
