install problem jornada 690
Help for PlanMaker 2004 for Handheld PCs
d.spiljard
Post by d.spiljard » Mon Oct 11, 2004 1:40 pm
I downloaded the trial op planmaker and installed them on my HPC jornada 690 with SH3 processor and ce 2.11. The installer gives that the installation is succesful. The program however does not start. When I examin the softmaker directory the application file pmc has 0 bytes. The software does not show in active sync 3.7.1 and in the settings of the HPC. Uninstall is not possible. I tried to install on the CF card and in the main memory, after performing a soft reset. All fails. What did I do wrong ? Please help me out, I´d like to buy this software as soon as possible. Could there be an issue with windows XP SP2 ?
Tobias-L
Post by Tobias-L » Mon Oct 11, 2004 2:07 pm
PlanMaker for Handheld PCs currently only supports ARM, StrongARM, XScale and MIPS CPUs. We don't support SH3 CPUs anymore as the compilers for this CPU type are very buggy.
Tobias Leißner
Return to “PlanMaker 2004 for Handheld PCs”
