Freezing Windows Not Being Saved
Help for PlanMaker 2004 for Handheld PCs
winfieldale
Post by winfieldale » Fri Mar 18, 2005 6:23 am
It seems that the action of freezing the window is not recorded as a 'change' to the file.
Create simple spreadsheet and save it. Now press the freeze button (bottom right of scrollbars) and notice that the window scrolling is properly locked. Then exit the program. At this point I expected a 'save file?' prompt to appear, but it doesn't and the program exits without saving the 'change'.
Not exactly earth-shattering, but something you might want to fix in a future service realease (I'm using release 280).
Kind Regards
Ian
Tobias-L
Post by Tobias-L » Mon Apr 04, 2005 4:49 pm
Thanks for the info. We will forward this report to our developers so they can take a look at it.
Tobias Leißner
Return to “PlanMaker 2004 for Handheld PCs”
