Does office 2010 for CE work on 1/2 VGA screen computers
Post your questions, bug reports and suggestions here for PlanMaker 2010 for Windows CE.
jmsiowa
Post by jmsiowa » Fri Oct 01, 2010 11:14 pm
We have several Daptech Microflex hand held computers running CE 5.0
http://www.daptech.com/products/ce8640_family
It lists the resolution as 1/2 VGA. So I assume it is just half screen. I was wondering if your program will work or does it need the full screen VGA to function. We would mainly be entering data into pre-made spreadsheets for field work on a plot by plot basis and would not need many cells visible for any given plot.
As it is we can only use these handhelds for one task with the special inhouse program, and I would like to get more use out of them.
John Shriver
Iowa State University
Research Associate
Re: Does office 2010 for CE work on 1/2 VGA screen computers
Post by martin-k » Sat Oct 02, 2010 8:02 pm
SoftMaker Office 2010 for Windows CE comes with two different screen layouts: low-res and hi-res. You would run the version built for "low-res" (320*240 pixels and higher) displays.
Return to “PlanMaker 2010 for Windows CE”
