Resolution Problem
Post your questions, bug reports and suggestions here for PlanMaker 2010 for Windows CE.
ceegee
Resolution Problem
Post by ceegee » Thu Aug 19, 2010 4:37 am
Hi, Just tried installing the CE version of Planmaker for 2010. Currently running the pocket pc version (hires) 2008 on a TDS Nomad which has a hires screen and runs well. The 2010 version seems to assume a much bigger screen, making it impossible to use. In fact to get past the iinitial dialog is not easy. Is there some setting to adjust the screen size for a 640x480 display? Am I using the correct version ie Pocket PC vs Windows CE (although for 2010 there only seems to be a CE version)? Thanks for any assistance.
Re: Resolution Problem
Post by sven-l » Thu Aug 19, 2010 9:02 am
Hello,
it seems that your device (TDS Nomad) comes with Windows Mobile, not with Windows CE. You need SoftMaker Office 2010 for Windows Mobile:
http://www.softmaker.com/english/ofpdemo_en.htm
ceegee
Post by ceegee » Mon Aug 30, 2010 3:32 am
Thanks Sven
That fixed the problem.
Return to “PlanMaker 2010 for Windows CE”
