Removes Background Color Formatting When File Is Closed
Post your questions, bug reports and suggestions here for PlanMaker 2010 for Windows Mobile.
AJ777
Post by AJ777 » Thu Feb 03, 2011 5:32 pm
When I use the background color option, save and close the file, then re-open the file the background color is changed to white again. I am using WM 6.5 on an ATT/HTC Tilt 2 PPC. Is this a known bug and if so when will it be fixed? Thank you.
Re: Removes Background Color Formatting When File Is Closed
Post by sven-l » Tue Feb 08, 2011 8:41 am
Are you saving in PlanMaker file format (.pmd) or another file format? Not all file formats are able to keep the background color information.
AJ777
Post by AJ777 » Tue Feb 08, 2011 6:51 pm
Sven, thank you for your quick reply. You are correct the background color information is retained when saved as a Planmaker file. Thought I tested this before I posted in Forum but guess I did not. Thank you.
Return to “PlanMaker 2010 for Windows Mobile”
