Drop down list valication formatting changes in 2010
Post your questions, bug reports and suggestions here for PlanMaker 2010 for Windows Mobile.
ceegee
Post by ceegee » Mon Aug 30, 2010 3:46 am
Hello
We have been trialling the use of the 2010 version of planmaker. One aspect which appears to have changed is the position of the drop down arrow for data validation lists. On 2008 the arrow appeared within the cell whereas for 2010 it appears to the right (outside) of the cell. Whilst this isn’t an issue for desktop based spreadsheets the small screen area of a pda creates a problem requiring us to lose some column width to display the arrow. Is there a setting to get the 2008 formatting in 2010?
Chris
Re: Drop down list valication formatting changes in 2010
Post by sven-l » Mon Aug 30, 2010 10:40 am
Hi Chris,
are you using Windows CE or Windows Mobile on your device? The screenshots seems to show the screen of an Windows Mobile device and you posted in the Windows CE forum. You can find the trial version for Windows Mobile here:
http://www.softmaker.com/english/ofpdemo_en.htm
ceegee
Post by ceegee » Wed Sep 01, 2010 1:09 am
Sven
Yes you are correct in that we are using the mobile edition. I probably should have put this in the mobile forum. We are using the trial version of the mobile verson based on the earlier issue we had with screen resolution with the CE version. We like the 2010 version and would obviously prefer to keep using this over the 2008 version. Just a little annoying to discover slight differences such as that highlighted with the dropdown box positioning.
Thanks for your help.
Chris
Post by sven-l » Wed Sep 01, 2010 8:51 am
I moved this topic into the correct forum.
Chris, can you please attach an small example file to reproduce this problem here on our Windows Mobile devices? Thank you!
ceegee
Post by ceegee » Thu Sep 02, 2010 1:37 am
Sven
The two photos sent through before were attempting to show the issue we are having. Whilst they are a bit blurry the sharper photo shows what we see with pocket pc 2008 planmaker where the drop down arrow (below the 8:00 cell when pda is in potrait view) is contained within the cell. The blurry photo is for mobile pc 2010 where the same cell (below the 8:00 cell) is showing the drop down arrow on the outside of the cell. Whilst not "earth shattering" this does mean that we have to make the column narrower so that the user can click on the drop down icon thus we lose some valuable screen real estate. If it was the desktop version I probably wouldn't care as the screen is so much bigger. With the pda version we are using the unit in an industrial plant setting and trying to make text as big as possible to improve readability. If necessary I can have another go at taking some better screen shots to try and show the issue better.
Chris
ceegee
Post by ceegee » Thu Sep 02, 2010 2:18 am
Sven
Created a small version of the file we are having issues with. Please see attached. If you go to cell E18 for example this will show the issue we are having between the two versions.
Chris
Example Problem.xls
(55.5 KiB) Downloaded 411 times
Post by sven-l » Thu Sep 02, 2010 8:07 am
Thank you! The problem is now reproducible for me and I referred this issue to our developers. I will inform you here as soon as I have more information.
Post by sven-l » Fri Sep 03, 2010 9:32 am
It seems that this behavior was changed in PlanMaker 2010 to make sure the dropdown arrow doesn't overlap the text inside the cell. Currently we don't plan to change this again.
ceegee
Post by ceegee » Mon Sep 06, 2010 12:38 am
Thanks Sven
Would be handy in the future if there is an option where the position can be toggled either inside or outside the cell. In any event I appreciated the quick feedback.
Regards
Chris
Marcolavida
Post by Marcolavida » Fri Dec 16, 2011 1:55 pm
I just want to set a variable myList to a list of values and then use myList for the content of my drop-down. Is this possible? It looks like the answer is no.
Al futuro
Post by sven-l » Mon Dec 19, 2011 8:53 am
Marcolavida wrote:I just want to set a variable myList to a list of values and then use myList for the content of my drop-down. Is this possible? It looks like the answer is no.
That's not yet possible but on the wish list for future versions.
Return to “PlanMaker 2010 for Windows Mobile”
