TM 2010 won't restart after I have started it once
Post your questions, bug reports and suggestions here for TextMaker 2010 for Windows Mobile.
yowlingcat
Post by yowlingcat » Fri Dec 31, 2010 4:50 pm
I am using TM2010 trial version on an HTC Advantage. I have installed it to internal memory.
The problem is that it will start once and works as it should. I then close the app and when I want to start it again, it won't do anything - the device doesn't freeze, at least not for a long time, but it won't start a second time until I have rebooted.
Is this a known issue? Any suggestions?
rjstep3
Re: TM 2010 won't restart after I have started it once
Post by sven-l » Mon Jan 03, 2011 2:49 pm
We suggest to install the program on an storage card and not on the internal memory. The problem is that not all of the memory is de-allocated when you close TextMaker. When you then start TextMaker again, it may be that there is not enough free RAM available. Installing the software on a storage card instead of the internal memory will give you more free RAM.
yowlingcat
Post by yowlingcat » Mon Jan 03, 2011 2:52 pm
thanks Sven - in fact I reloaded the ROM again, and it seems to be better, though a little termperamental (probably due to WinMo more than anything else).
I'll uninstall and try using from the SD card - thanks for replying.
rjstep3
Return to “TextMaker 2010 for Windows Mobile”
