Can't use keyboard number pad
Post bug reports and suggestions for the PlanMaker 2010 for Windows Mobile beta software.
adekunledauda
Post by adekunledauda » Tue Jun 15, 2010 4:31 pm
Hi,
I have HD2 ppc and can used the keyboard on the mobile to enter number in the cell.
Also, when opening excel 2007 file i.e xlsx file comes up with arabic character. I used english version and know why the spreadsheet open with Arabic Character.
Raheem
DrAT
Re: Can't use keyboard number pad
Post by DrAT » Wed Jun 16, 2010 5:37 am
I can confirm the number pad problem on the HD2. When selected, it switches back to the normal on-screen keyboard.
WM2003SE - HP iPAQ hx4700 - 64Mb RAM
WM5 - XDA Mini S
WM6 - HP iPAQ 214 - 128Mb RAM
WM6.5 - HTC HD2 - 448Mb RAM
StowAway BT Keyboard
Post by sven-l » Wed Jun 16, 2010 9:09 am
Thank you for the bug report. I referred it to the developers and will inform you here as soon as I have more information.
JohnMOwens
Post by JohnMOwens » Thu Jun 17, 2010 11:35 pm
I have the same problem on the HTC Touch Pro 2 (AT&T Tilt 2) when using the Full QWERTY keyboard where the number pad switches back to the alpha keyboard immediately. However, if I switch from the Full QWERTY keyboard to the normal keyboard (WM 6.5 default) then I can use the number pad from it.
Note: This also happens in BETA: TextMaker 2010 for Windows Mobile
AT&T Tilt 2
Windows Mobile 6.5
SPB Mobile Shell 3.5.5
Philip-J
Post by Philip-J » Thu Jun 24, 2010 1:36 pm
Hello,
the bug is fixed. It will works in the final release.
Philip Jedamzik
richardm
Post by richardm » Sun Jun 27, 2010 2:10 pm
Hi Philip-J
When will the final release be available as this bug makes the beta PlanMaker (and TextMaker) unusable?
If it is going to be a long time, can you issue a new beta with that bug fixed?
Thanks,
Richard
Philip-J
Post by Philip-J » Tue Jun 29, 2010 1:56 pm
Hello Richard,
the final release of SoftMaker Office 2010 for Windows Mobile will be available on the 1st of July 2010.
Philip Jedamzik
Return to “Beta: PlanMaker 2010 for Windows Mobile”
