Refuses to print -no problem with LibreOffice
Post bug reports and suggestions for TextMaker 2010 for Linux.
Puppy-Tester
Post by Puppy-Tester » Fri Sep 07, 2012 7:57 pm
When I hooked up my Epson Artisan700 printer and made it the default I was able to print a few pages from Textmaker 2010 for Linux. After I printed one in LibreOffice it won't do anything in Textmaker.
Re: Refuses to print -no problem with LibreOffice
Post by sven-l » Mon Sep 10, 2012 10:04 am
Does it help to remove the printer and add it again?
Puppy-Tester
Post by Puppy-Tester » Sat May 03, 2014 8:10 pm
No. I am now having a similar problem with Officejet J4540 {4500} ,works fine in LibreOffice but not 2010 Textmaker on LinuxMint 16 Mate. It won't allow me to delete the default system printer.
Do I have to uninstall 2010 to try 2012?
Also why is there no guide for 2010 Linux version of Soft maker?
Post by sven-l » Mon May 05, 2014 10:15 am
I would suggest to uninstall Office 2010 and try it with the Office 2012 demo version:
http://www.softmaker.com/english/ofldemo_en.htm
You can use the following commands in the shell to install/uninstall SoftMaker Office on your machine (please replace the names of the files and installations with the correct ones):
TGZ:
install: tar xzf softmaker-office.tgz
uninstall: our script (uninstallsmoffice)
RPM:
install: rpm -ivh softmaker-office.rpm
uninstall: rpm -e softmaker-office
list all installed packages: rpm -qa
list all installed Softmaker Office packages: rpm -qa | grep softmaker
DEB:
install: dpkg -i softmaker-office.deb
uninstall: dpkg -r softmaker-office
list all installed packages: dpkg --get-selections
list all installed Softmaker Office packages: dpkg --get-selections | grep softmaker
You can download the user manuals here:
http://www.softmaker.com/english/manuals_en.htm
...and finally here are some Tips and Tricks for SoftMaker Office Linux:
http://www.softmaker.com/english/tipslinux_en.htm
I hope this helps you sorting that problem out.
Puppy-Tester
Post by Puppy-Tester » Mon May 05, 2014 7:15 pm
sven-l wrote:I would suggest to uninstall Office 2010 and try it with the Office 2012 demo version:
Will give it a shot
TGZ:
RPM:
DEB:
Return to “TextMaker 2010 for Linux”
