Xrender initialization failed
This forum is for questions, suggestions, and issues that are general to SoftMaker Office 2010 for Linux and not specific to one of its applications.
jhecker
Post by jhecker » Tue Jun 24, 2014 4:43 pm
New installation of Lubuntu 13.04. Installed the products fine; they work perfectly at home in front of my screen. Now accessing my system via (free)RDP. Other GUI products are working fine; when trying to start Textmaker I consistently get the error 'Xrender initialization failed'. Where should I start troubleshooting? X works, or XFCE4 wouldn't be running.
Thank you.
Kind regards,
Jared Hecker
Re: Xrender initialization failed
Post by sven-l » Wed Jun 25, 2014 9:38 am
Does it help to deactivate SHM and XIM in Tools=>Options=>System?
thierry
Post by thierry » Mon May 11, 2015 11:08 am
Hello,
I have the same problem with a Debian 7 Xfce 4.8 installation. I used a screen session to run TextMaker for disabling Xrender, XIM and SHM and reboot the system. When I try to use TextMaker via xrdp, I always have the message "XRender initialization failed" but LibreOffice Writer works well.
Here is my config file :
thierry@PC8:~/.softmaker$ cat tmfoconfig.ini
[PrinterList]
Default Printer Queue [System]=4
[SM Printer - Default Printer Queue [System]]
PrinterCmd=lpr -r %
PrinterOutput=1
Resolution=96
RotLandscape=1
[DefaultPrinter]
DefaultPrinter=Default Printer Queue [System]
[tm]
LinuxInfo=2012.LX.698.1
AdsLastDate=11.5.2015
DlgLID=1033
TemplatePath=/home/thierry/SoftMaker/Templates 2012/
Documents=/home/thierry/SoftMaker/
Databases=/home/thierry/SoftMaker/
Pictures=/home/thierry/SoftMaker/
Macros=/home/thierry/SoftMaker/
XRenderBitBlit=0
TimeFormat=
DateFormat=
TimeFlags=0
DateFlags=0
SidebarDocking=3
SidebarRatio1=-1
SidebarRatio2=-1
HideSBFullScreen=0
SidebarPage=3391
SidebarDocumentMap=1
SidebarHeadingLevel=9
SidebarCharstyleShow=0
SidebarPgfstyleShow=0
SidebarAdPic=1
SidebarAdDate=11.05.2015
SidebarFlags=1023
WSColorEnabled=0
WSColorRGBValue=9343379
LanguageID=1033
SpellRule=1
InfoDropdown=1
HorizontalPages=32
WinSize=0,0,1536,864
Shm=0
UseXIM=0
[UserHome]
Name=
[UserBusiness]
Name=
[Ignore]
OLE=0
[Intl]
iMeasure=1
Thank you.
Best regards,
Thierry
Post by sven-l » Tue May 12, 2015 10:07 am
Are you starting TextMaker via the command line (textmaker12)?
thierry
Post by thierry » Tue May 12, 2015 7:01 pm
No, I started with the Textmaker icon from the desktop. When I start with the command line "textmakerfree" (I use the free version), I have the same Critical System Error message = "XRender initialization failed" even as root user. I join a screenshot from the message.
Thank you.
Thierry
Post by sven-l » Wed May 13, 2015 9:19 am
I will refer that problem to our developers. Just one more question: Does PlanMaker or Presentations start or is there the same error message?
thierry
Post by thierry » Wed May 13, 2015 11:28 am
There is the same error message with PlanMaker and Presentations.
Thank you.
Thierry
Return to “General”
