Font compatibility issue between with SoftMaker Presentation
Post bug reports and suggestions for SoftMaker Presentations 2010 for Windows.
NN1
Post by NN1 » Mon Dec 06, 2010 11:03 pm
Hi Team,
My wife uses OpenOffice 3.3 to edit PowerPoint files, and save them in MS Powerpoint 97/2000/XP format.
Now Whenever I open the ppt files from her on my own computer with SoftMaker Presentation 2010 (service pack 591), and save the file as Ms Powerpoint 2000/XP/2003 format, my wife gets all the font displayed in white color, single strike-through, Single underlying on her computer !
I also tried to use my office PC with MS Office 2003 to edit a powerpoint file.
Then I used my home PC with SoftMaker Presentation 2010 (service pack 591) to read the powerpoint file, and saved again as Ms Powerpoint 2000/XP/2003 format.
Then from My office PC with MS Office 2003 I still get the same issue as my wife with all the font displayed in white color, single strike-through, Single underlying on my office computer !
See picture attached.
I have also attached the original file created with OpenOffice 3.3 (Original_OpenOffice3.3.ppt)
and the same saved with SoftMaker Presentation 2010 - service pack 591- as Ms Powerpoint 2000/XP/2003 format. (Presentation_save_as_powerpoint_2000-XP-2003.ppt)
Please let me know if this is a know issue !
Thanks & Regards
FreePix
(32.5 KiB) Downloaded 244 times
(72.5 KiB) Downloaded 252 times
FreePix
SoftMaker Office 2010 User (Revision 591)
Re: Font compatibility issue between with SoftMaker Presenta
Post by sven-l » Tue Dec 07, 2010 10:26 am
Thank you for the bug report and the sample files. I can reproduce this problem here and informed our developers.
NN1
Post by NN1 » Thu Dec 30, 2010 12:48 am
Hello Sven,
Do you know if this issue will be quickly addressed ?
For now I am unfortunately forced to use MS Office or OpenOffice as the font color are not properly handled by Softmaker presentation.
Regards
FreePix
Post by sven-l » Mon Jan 03, 2011 10:52 am
I raised the priority for this problem and will inform you as soon as we have an solution.
Return to “SoftMaker Presentations 2010 for Windows”
