Presentation is slow
Post bug reports and suggestions for SoftMaker Presentations 2010 for Windows.
ymtong
Post by ymtong » Tue Oct 12, 2010 1:54 am
I'm not sure if other users are experiencing problems in getting Presentations to work quickly. It is so sluggish as compared to Powerpoint or I'm missing something?.....not sure if this was ever raised in the forum.
Re: Presentation is slow
Post by sven-l » Tue Oct 12, 2010 11:01 am
Hello,
which revision of Presentation do you use (Help=>About)? The current one is 584. Does the speed problem occur with every file? Could you please send us an example file to forum(at)softmaker.de? Thank you!
ymtong
Post by ymtong » Sun Oct 17, 2010 11:32 am
Hi...and thanks for following up. I'm having the latest update 584. Nevertheless; I will attempt to duplicate another presentation and to be sent shortly.
BjornF
Post by BjornF » Fri Jan 07, 2011 11:39 am
Dear Ymtong,
you are not alone in this, I have exactly the same problem.
all the best/ Björn
Post by sven-l » Fri Jan 07, 2011 11:45 am
BjornF wrote:Dear Ymtong,
all the best/ Björn
Without an example file theres not much we can do here. Can you please send us such a "sluggish" file to forum(at)softmaker.de? Thank you!
Beamer
Post by Beamer » Thu Jun 16, 2011 8:05 pm
Animated text is jerky / not smooth compared to Microsoft PowerPoint Viewer 2010.
Slide # 9 in file: http://www.cs.uky.edu/~keen/intro/labs/ ... rpoint.ppt
Post by sven-l » Fri Jun 17, 2011 10:14 am
Thank you for the example file. I informed the developers.
Return to “SoftMaker Presentations 2010 for Windows”
