Strange results when trying to load a file by dragging
Post bug reports and suggestions for PlanMaker 2010 and PlanMaker Viewer 2010 for Windows.
Neil_Parks
Post by Neil_Parks » Fri Feb 04, 2011 6:00 pm
I have encountered this phenomenon in both Plan Maker 593 and PM beta 635.204. I am using Win XP sp3.
I have Plan Maker open on the screen. I open Windows Explorer ("My Computer"). I select an XLSX file and drag it onto PM. Instead of the open spreadsheet that I was expecting, the file appears as some sort of icon that I don't know what to do with.
But wait--it gets stranger.
I have closed and re-opened PM.
Instead of Windows Explorer, I open an alternative file manager such as 7-Zip or Gyula's Navigator. This time, when I drag the XLSX onto PM, the spreadsheet opens normally, and I can work with it.
But when I try to exit from Plan Maker, it does not completely close. The file manager is locked until I open Task Manager and kill the Plan Maker process that is still in memory.
"Program in haste; debug at leisure."
Re: Strange results when trying to load a file by dragging
Post by sven-l » Tue Feb 08, 2011 9:27 am
I can reproduce the problem with the 7zip file manager here and informed the developers.
When you drag a document into the worksheet, PlanMaker tries to create an OLE object for the document there. To *open* the file instead, drag it onto the title bar of PlanMaker's program window.
Post by sven-l » Wed Feb 23, 2011 10:47 am
This has been fixed now and will work better in the next version of SoftMaker Office.
Return to “PlanMaker 2010 for Windows”
