removing duplicates is not possible???
Post bug reports and suggestions for PlanMaker 2010 and PlanMaker Viewer 2010 for Windows.
trsteve
Post by trsteve » Tue Dec 21, 2010 11:35 pm
Hi,
Today i wanted to remove duplicates, but just find out that it this function is missing? I had to import the spreadsheet in another program just to remove the duplicates in a long list.
Do i mis something here or is it really not possible to remove duplicates? If it's not there, then that is for sure something to build in to a next patch/version.
Also there doesn't seem to be a pivot table/graphic function in Planmaker, while it is in the free openoffice software. Any idea when this becomes available in Planmaker?
Also, a function that i would love to see in a future version is the possibility for conditional formatting without limits, where for now you can only set 3 conditional formatings, and in excel you can set an unlimited amount of conditional formattings. When i asked for this about 3 years ago someone mentioned they would look into it to include it in a new version.
Greetings,
Steve
Re: removing duplicates is not possible???
Post by sven-l » Wed Dec 22, 2010 8:48 am
Hello,
all those features are already on the todo list for future versions but not yet implemented in PlanMaker.
Return to “PlanMaker 2010 for Windows”
