Embedding Planmaker spreadsheet into Textmaker
Post bug reports and suggestions for TextMaker 2010 and TextMaker Viewer 2010 for Windows.
ericinoz
Post by ericinoz » Wed Nov 30, 2011 12:00 pm
I have just spent most of the day trying to embed a spreadsheet that I created in Planmaker into a Textmaker document that I am working on. I opened the help file on my second monitor and followed the instructions to the letter, still no embedding. I did at one time get some sort of spreadsheet into Textmaker but half the rows were missing and it appeared at the bottom of the page and I couldn't move it. If I try embedding the spreadsheet as a pdf file I just get an icon. I have tried using both create an OLE object and an Object Frame. Neither works. I am rapidly running out of patience.
Re: Embedding Planmaker spreadsheet into Textmaker
Post by sven-l » Thu Dec 01, 2011 8:44 am
To embedd an OLE object frame should work properly. Make sure to use the correct PlanMaker file<<<<< in the dialog when creating the OLE object frame. The data that you want to see in the frame should be in the upper left corner of the PlanMaker file.
ericinoz
Post by ericinoz » Thu Dec 01, 2011 12:13 pm
I tried again today, got it in once but cropped. Tried again and nothing appeared. Finally placed the file by cut and paste, much easier.
Return to “TextMaker 2010 for Windows”
