Picture frames keep disappearing
Post bug reports and suggestions for TextMaker 2010 and TextMaker Viewer 2010 for Windows.
David.Boettcher
Post by David.Boettcher » Fri Sep 30, 2011 1:12 pm
I am working on the final edit of a document. It is 11 pages long and contains 25 picture frames with captions, 3 text boxes and 1 table, so the density of frames/pictures/boxes is quite high.
Sometimes when I make an edit a picture disappears, i.e becomes no longer visible. If I ctrl-z to undo the edit it reappears, but is there another way to force all the pictures etc. in a document to shown themselves? And why does it happen - it is quite disconcerting.
Regards - David
Re: Picture frames keep disappearing
Post by Jossi » Fri Sep 30, 2011 4:16 pm
First check the object properties of these picture frames, tab "Layout". If they are set to "Move with text" and "Move with object", they might jump sometimes to other pages and disappear from sight. With "Fix on page" they are bound to stay where they are.
Return to “TextMaker 2010 for Windows”
