HyperTips
Post bug reports and suggestions for TextMaker 2010 and TextMaker Viewer 2010 for Windows.
robertbogner
HyperTips
Post by robertbogner » Wed Dec 15, 2010 12:24 pm
Softmaker Tips are very good and I learn a lot, and - forget a lot!
Maybe some others have the same problem.
I know I can get back to a tip that I half remember seeing by "Help/Tip of the day", but then I have to jump "Next tip" until the one I half-recall appears.
How about a (hyper) tip that says
"You may see all Tips by using "Help/Search/Tips" or Index and in the resultant text have the tips serially viewable, OR - have the Tips detailed in the Help/Contents list. I think you can make this work well!
Re: HyperTips
Post by sven-l » Wed Dec 15, 2010 12:57 pm
Hello,
I referred your suggestion as a feature request to our developers.
Return to “TextMaker 2010 for Windows”
