Create script to print my fonts
Post bug reports and suggestions for TextMaker 2010 and TextMaker Viewer 2010 for Windows.
csrocha
Post by csrocha » Tue Apr 02, 2013 3:22 pm
I need a script that generates a document listing all the fonts installed on my PC. Using Windows 7 Home Basic.
Can someone help?
Re: Create script to print my fonts
Post by martin-k » Tue Apr 02, 2013 3:24 pm
Check out the script ALLFONTS.BAS that is included with SoftMaker Office. Run it from within BasicMaker.
csrocha
Post by csrocha » Tue Apr 02, 2013 4:08 pm
Thanks, but when I execute allfonts.bas, I get an error:
' Add an empty document
tm.Documents.Add
error in line 34: The object invoked has disconnected from its clients. (my version is Portuguese, so I did translate with help from Google....)
line 34 is tm.Documents.Add
Post by sven-l » Thu Apr 04, 2013 8:32 am
The script runs perfectly for me with BasicMaker 2010 and BasicMaker 2012. I asked the developers what could be the problem on your side.
Do you use a trial version or a version with a welcome-screen on start?
csrocha
Post by csrocha » Fri Apr 05, 2013 5:28 am
My version is full, there is a welcome-screen. Its version is 2012, rev 600.
Return to “TextMaker 2010 for Windows”
