File causing a crash
This beta forum will be closed soon. Please post in the regular forum for PlanMaker 2010 for Windows.
Gummby
Post by Gummby » Sat Nov 21, 2009 12:54 am
I have an old .XLS file which I converted to .PMD. Program crashed after I saved it. Then, when I went to open back up the .PMD document, it crashed immediately.
I've attached both docs for your review.
Daily Support Tools (liter).xls
(97.4 KiB) Downloaded 226 times
Daily Support Tools_2009.pmd
(100.5 KiB) Downloaded 210 times
jimjutte
Re: File causing a crash
Post by jimjutte » Sat Nov 21, 2009 8:18 am
Well... I have good news and bad.
The bad news is, I took out the brackets in the file name and it opened fine. Thinking that it was the brackets, I opened the file with the brackets still in... and it did not crash...
The good new is... when I opened up the .pmd file... it crashed...So... whatever the problem is, I can duplicate it.
Cheers
Jim
Post by sven-l » Mon Nov 23, 2009 9:40 am
Thank you for the bug report and the example file. I were able to reproduce the crash and informed the developers.
Post by sven-l » Mon Nov 23, 2009 10:13 am
In the 'mortgage calculator' sheet is an invalid number in O12. If you remove it the file loads fine. I attached the repaired file.
Daily Support Tools (liter)_r.zip
(23.74 KiB) Downloaded 170 times
jimjutte
Post by jimjutte » Tue Nov 24, 2009 8:59 am
Sven,
It seems rather an extreme reaction of the file to crash the program completely rather than simply show an error in a given cell. Or have I misunderstood the problem?
Cheers
Jim
Post by sven-l » Tue Nov 24, 2009 3:34 pm
In this case it was just the wrong value in O12 that caused the problem.
Return to “Beta: PlanMaker 2010 for Windows”
