Hungarian Spell-checking?
Post bug reports and suggestions for TextMaker 2008 for Linux.
zsola
Post by zsola » Fri Oct 14, 2011 8:15 am
Hi!
Is there any hungarian spell-checking plug-in available for SoftMaker Office 2008?
Thanks in advance:
Zsola
Re: Hungarian Spell-checking?
Post by martin-k » Tue Oct 18, 2011 9:12 am
No, unfortunately there isn't. And due to the peculiarities of the Hungarian language (it's an agglutinative language, which makes developing a spell checker very hard), I don't think there will be one in the foreseeable future.
zsola
Post by zsola » Thu Oct 20, 2011 1:36 pm
Dear Martin,
Thanks for your kind replay.
Indeed the hungarian language is not the simplest language on the planet. :o
Anyway it wouldn't be possible to use an external spell-checker library, like hunspell, as OpenOffice and the others do?
Thanks in advance
Zsola
zsola
Post by zsola » Wed May 23, 2012 11:46 am
Hi!
Big THANKS for the HunSpell fuature in SM Office 2012! Can I use it somehow for the SM Office 2008 on linux?
Zsola
Post by sven-l » Wed May 23, 2012 11:59 am
zsola wrote:Hi!
Zsola
No, but it will be possible to use the HunSpell dictionaries in TextMaker 2012 for Linux.
jimjutte
Post by jimjutte » Thu May 24, 2012 3:33 am
I recognize this might not be an ideal solution, but you might consider using an open source application that uses a Hungarian spell checker to type your text and once you're document is complete simply copy and paste it into TM to complete whatever formatting needs you have.
Just a thought. I apologize I am not familiar with Hungarian other than... I have heard it is quite difficult to learn... and I'm learning Mandarin at the moment. :)
Cheers
Jim
zsola
Post by zsola » Thu May 24, 2012 10:40 am
Thanks for your replay!
Ok. I'll try it with S.M.O. 2012.
Anyway, I don't know, just think that the Mandarin is much more complicated than Hungarian language. So if you can learn it, you should give a try for Hungarian too. :)
Thanks again.
Zsola
jimjutte
Post by jimjutte » Thu May 24, 2012 10:49 am
One language at a time... I was to remain sane ;)
Cheers
Jim
Return to “TextMaker 2008 for Linux”
