Softmaker for 64 bit Linux
Post bug reports and suggestions for TextMaker 2008 for Linux.
theTechnaddict
Post by theTechnaddict » Fri Aug 26, 2011 1:16 pm
Hiys - I have a number of people in our small education charity, who are fed up with LibreOffice - but I can't install SoftMaker 2008 because the deb files are for a 32 bit architechture....
Is there a way of installing (any version) on a 64 bit architechture?
Re: Softmaker for 64 bit Linux
Post by martin-k » Fri Aug 26, 2011 1:19 pm
theTechnaddict
Post by theTechnaddict » Fri Aug 26, 2011 1:37 pm
Thanks for your superfast reponse.
I have not been able to find a 64 .deb for 2008 - there does appear to be one for 2010 - although I take the point that it is a 32 bit compilation with the required 32 bit libraries.
From the command line I've navigated to the download folder and issues the folloing:
$ sudo dpkg -i --force-all softmaker-office-2008_i386.deb
It appears to have worked so far - though it is ugly as sin.
theTechnaddict
Post by theTechnaddict » Fri Aug 26, 2011 1:39 pm
Please forgive me for posting in the wrong board - this should be in hte 2008 for linux board...
Post by martin-k » Fri Aug 26, 2011 1:44 pm
You can at least switch to a different font and font size for the dialog boxes by editing your tm08config.ini file. Add this:
[tm]
DlgFont=Sans-PS
DlgFontSize=14
Then start playing with the font name and the size until you are satisfied.
Return to “TextMaker 2008 for Linux”
