Plans fot 64-bit Linux?
Post bug reports and suggestions for TextMaker 2008 for Linux.
EaglePrince
Post by EaglePrince » Mon Jan 04, 2010 1:58 pm
Hello there,
I have tried searching for any talk of 64-bit versions ((Linux and Windows) but found nothing so far.
My 2008 version (free Linux version) installs fine but doesn't run. Well of course it doesn't, as I run a full-fledged 64-bit system with Vista and Salix OS, a Slackware derivative. So unfortunately, I can't offer to beta-test the 2010 version either! :(
So my question is, when, if any time soon, should we expect 64-bit versions of the SoftMaker suite?
EricC
Re: Plans fot 64-bit Linux?
Post by EricC » Mon Jan 04, 2010 4:50 pm
I can confirm SMO2008 for Linux will not run on Salix x64 13.02a. I did an install for all users.
I get the following message:
/usr/bin/textmaker: line 3: /usr/share/office2008/textmaker: No such file or directory
Even get the same message if I try to run as root.
Post by martin-k » Mon Jan 04, 2010 4:53 pm
You need to install the 32 bit system libraries. We'd love to give specific instructions, but every distribution does it differently...
Return to “TextMaker 2008 for Linux”
