Copy and paste text from TM doc files causes TB to crash
Post bug reports and suggestions for TextMaker 2008 for Linux.
matteo
Post by matteo » Thu Dec 10, 2009 11:52 am
This is an odd bug I found out. If I copy some text from a .doc file in TM with ctrl+c, when I try to past it in an email message in Thunderbird, doing ctrl+v causes TB to close instantly.
Awkward isn't it? :shock:
ps same thing doesn't happen if I copy and paste from other applications...
Re: Copy and paste text from TM doc files causes TB to crash
Post by sven-l » Thu Dec 10, 2009 12:58 pm
I'm not 100% sure but I think that we already had that or a very similar problem in the past. What Linux distribution and thunderbird version do you use? Does it happen with every TextMaker file you copy text from? Can you send us an example file please?
matteo
Post by matteo » Thu Dec 10, 2009 1:47 pm
sven-l wrote:I'm not 100% sure but I think that we already had that or a very similar problem in the past. What Linux distribution and thunderbird version do you use? Does it happen with every TextMaker file you copy text from? Can you send us an example file please?
I'm using TB 2.0.0.23, on Ubuntu 9.04 (I haven'y upgraded yet). Please find attacched an example file.
BR
Capitoli 8-9.doc
(32.5 KiB) Downloaded 306 times
Post by sven-l » Thu Dec 10, 2009 2:43 pm
Thanks, I've informed our developers to investigate this issue. Please note that there will be no more Service Packs for the Office 2008 for Linux but it should work better in SoftMaker Office 2010 for Linux and you' ll receive the free upgrade then.
Post by sven-l » Thu Dec 10, 2009 3:49 pm
Please have a look at this thread http://www.softmaker.com/diskussion/vie ... 442#p43442
There's a bug in Thunderbird. They probably has been fixed it in November, but not yet released a new version.
mb
Post by mb » Thu Dec 10, 2009 5:04 pm
But that thread is in German, Sven. 8-)
Anyway, more info on the bug and patches can be found here:
https://bugzilla.mozilla.org/show_bug.cgi?id=495392
Martin Baumgärtner
matteo
Post by matteo » Fri Dec 11, 2009 10:14 am
mb wrote:But that thread is in German, Sven. 8-)
Kein Problem fuer mich... Ich dachte nur dieses Forum sei international und man sollte deswegen auf englisch schreiben... :)
I'll see whether I can fix the bug! tx
Return to “TextMaker 2008 for Linux”
