File formats
Post bug reports and suggestions for TextMaker 2008 for Linux.
carandol
File formats
Post by carandol » Sun Jul 05, 2009 3:09 pm
Since most of the work I do in TextMaker involves creating, editing and making changes to .doc files, I'm wondering what the differences are between native TextMaker files and those saved in Word format. If I switch to saving automatically in Word format, is there anything I'm likely to lose, format-wise? I'm mostly working with straight text, the only likely graphic being an occasional photograph. I use the track changes functions and comments, and quite often the table of contents generator. Otherwise it's fairly simple, the most complex layout being double columns occasionally, and the odd footnote.
carandol
Re: File formats
Post by sven-l » Mon Jul 06, 2009 2:58 pm
Hello,
the tmd-format can save all functions that TextMaker offers. The doc-format stores only functions supported by MS Word. If you, for example, use shortcuts for stylesheets or user-defined colors, they are not supported in Word and will be lost if you save in doc format.
carandol
Re: File formats
Post by carandol » Mon Jul 06, 2009 3:18 pm
sven-l wrote:the tmd-format can save all functions that TextMaker offers. The doc-format stores only functions supported by MS Word. If you, for example, use shortcuts for stylesheets or user-defined colors, they are not supported in Word and will be lost if you save in doc format.
I don't suppose there's a list anywhere of TextMaker-specific functions which Word doesn't support? It's a couple of years since I last used Word regularly, so it's difficult to know what functions I should be avoiding when preparing documents for others.
carandol
Re: File formats
Post by martin-k » Thu Jul 09, 2009 11:43 am
No, unfortunately we don't have such a list. But these are really minor differences that should (maybe with the exception of user-defined colors) not affect the display of documents in Word.
carandol
Re: File formats
Post by carandol » Wed Jul 15, 2009 1:37 am
OK thanks!
carandol
carandol
Re: File formats
Post by carandol » Sat Jul 18, 2009 12:09 pm
martin-k wrote:No, unfortunately we don't have such a list. But these are really minor differences that should (maybe with the exception of user-defined colors) not affect the display of documents in Word.
OK, thanks. I don't use user-defined colours, so I guess I don't need to worry!
carandol
Return to “TextMaker 2008 for Linux”
