Portuguese keyboard
Post bug reports and suggestions for TextMaker 2008 for Linux.
abacanto
Portuguese keyboard
Post by abacanto » Thu Dec 18, 2008 12:33 pm
Portuguese special caracters dont work ... and the keyboard is ok in ubuntu and works very well in openoffice :(
Re: Portuguese keyboard
Post by sven-l » Fri Dec 19, 2008 12:05 pm
Hello,
does it mean that you cannot type in Portuguese chars or that Portuguese chars are not displayed correctly?
abacanto
Post by abacanto » Fri Dec 19, 2008 7:22 pm
My english is a little poor.
I can't for example put the "~" in the a like â or ã or write "à or á" cause the keyboard don't let this.
bohux
Post by bohux » Mon Dec 29, 2008 8:18 pm
Same problem with czech characters (deadkeys - 2key press characters) like ď ť ň. Copy/Paste this character from another application e.g. firefox to textmaker is OK.
Post by sven-l » Fri Jan 02, 2009 8:50 am
Thank you both for your advice!
Please make sure that the keyboard layout in your Linux is set to your language. Does the problem then still exist? Does the special characters appear without problems in Open Office Writer? What Linux distribution do you use?
bohux
Post by bohux » Fri Jan 02, 2009 6:35 pm
Keyboard layout is set to czech. No problem in openoffice writer. My distribution is debian.
Post by sven-l » Mon Jan 05, 2009 8:49 am
Thank you! I referred that problem to our developers and will contact you as soon as I have more information.
Post by sven-l » Tue Mar 16, 2010 11:15 am
The problem has been solved and should no more occur with in the current beta version.
Return to “TextMaker 2008 for Linux”
