Change default save directory
Post bug reports and suggestions for TextMaker 2008 for Linux.
Munchkinguy
Post by Munchkinguy » Mon Jun 11, 2012 11:15 pm
I would like to change my default save directory to My Documents. Currently, it is My Documents/Softmaker/Templates/English, which is not a very good place for finished documents.
Re: Change default save directory
Post by martin-k » Tue Jun 12, 2012 9:05 am
The applications in SoftMaker Office always load/save from/to the last directory that a document was opened from or saved to.
Simply load a document from the desired location once, and the directory will be offered in the next File/Open.
If you have multiple directories that you want to access quickly, set up some QuickPath entries in the file dialog.
Return to “TextMaker 2008 for Linux”
