Ctrl-Alt-Shift-F12
Bug reports for TextMaker 2008 for Linux
carandol
Ctrl-Alt-Shift-F12
Post by carandol » Sun Sep 28, 2008 2:36 pm
The Ctrl-Alt-Shift-F12 command, which is supposed to allow you to type in the hex number of a Unicode character, is interpreted (in Linux Mint Elyssa, at least), as the Gnome command Ctrl-Alt-F12, which switches off the GUI. This leaves one with a black screen and a feeling of panic :o Luckily, one can return to normal with Ctrl-Alt-F7. But definitely a bug to be fixed, because it's really bad for the blood pressure! :)
carandol
Re: Ctrl-Alt-Shift-F12
Post by sven-l » Mon Sep 29, 2008 2:26 pm
Hello,
I referred that problem to our developers and will inform you here as soon as there are any news.
mb
Post by mb » Wed Oct 01, 2008 5:25 pm
You're right. The keyboard shortcut Ctrl+Alt+Shift+F12 works only under Windows. Under Linux, Ctrl+Alt+Shift+X has to be used. Manuals will be updated accordingly.
Martin Baumgärtner
Return to “BETA TextMaker 2008 for Linux”
