Dates in comments
Bug reports for TextMaker 2008 for Linux
carandol
Dates in comments
Post by carandol » Fri Sep 19, 2008 7:07 pm
Not sure if this counts as a bug, or just an annoying niggle, but it would be nice if dates in comments were in the standard UK format of day/month/year when the language is set to UK English, rather than the confusing US system of month/day/year.
carandol
Re: Dates in comments
Post by sven-l » Mon Sep 22, 2008 8:48 am
Hello,
currently TextMaker takes the format of the date (dd/mm/yyyy or mm/dd/yyyy) from the System settings. If you have chosen US English as your regional settings the date will be month/day/year and if you have chosen UK English it will be day/month/year.
I will refer a feature request to our developers that TextMaker will take the time and date format from the user interface settings of TextMaker instead from the System settings.
carandol
Post by carandol » Mon Sep 22, 2008 1:04 pm
As far as I'm aware, my system is set to UK English. Certainly GNOME says it is. Do you know what underlying file I'd need to check to make sure it's *really* set right?
carandol
Post by sven-l » Mon Sep 22, 2008 4:24 pm
Can you please tell us what Linux distribution you use?
Thank you!
carandol
Post by carandol » Mon Sep 22, 2008 4:38 pm
Oops, sorry, should have thought of that :-) Linux Mint Elyssa. (based on Ubuntu Hardy Heron).
carandol
Post by sven-l » Mon Sep 22, 2008 4:47 pm
Ok, please try the following commands in the shell:
echo $LANG
echo $LC_ALL
echo $LC_LANG
Can you please post the results here?
Thanks again :)
carandol
Post by carandol » Mon Sep 22, 2008 5:27 pm
The results are:
ken@ken-laptop ~ $ echo $LANG
en_GB.UTF-8
ken@ken-laptop ~ $ echo $LC_ALL
ken@ken-laptop ~ $ echo $LC_LANG
(i.e. just a blank line for the second two commands). No idea if this is good or bad! :)
carandol
Post by sven-l » Tue Sep 23, 2008 4:32 pm
Hello,
we could reproduce this problem and referred it to our developers. I will inform you here as soon as I have more information.
Post by sven-l » Thu Sep 25, 2008 4:23 pm
Hello,
the problem could be solved by our developers and won't occur in the next Beta.
Return to “BETA TextMaker 2008 for Linux”
