Slowdown typing Korean on MobilePro 900C
Post bug reports and suggestions for TextMaker 2008 for Windows CE.
sphinx32
Post by sphinx32 » Sat Feb 28, 2009 3:10 pm
Hello,
I have installed trial version of textmaker 2008 on my NEC MobilePro 900C (CE .net 4.2) and having some issue for typing Korean.
When I typed Korean charactors, displaying charactors delays are so long (depends on how many char has typed, but
typically 5~6 seconds later, it displayed). I have autospell checker has disabled, and having still same problem.
I found some more interesting things;
- For English typing is acceptable delay.
- Tried PlanMaker 2008, and Korean typing delay was acceptable.
So, my question is, Delaying on Asian charactors are know issue or is there any setting on textmaker to solve this kind of delay?
Thanks in advance.
WJ
jimjutte
Re: Slowdown typing Korean on MobilePro 900C
Post by jimjutte » Sun Mar 01, 2009 2:28 pm
Just a quick question. Do you use the desktop version as well? Do you notice if this occurs on the desktop version as well? Or is this just a CE issue for you?
Cheers
Jim
sphinx32
Post by sphinx32 » Sun Mar 01, 2009 3:48 pm
I have installed desktop verion of textmaker, and it has no problem of this kind of issue.
I'm currently encountered this problem with only Win CE on MobilePro 900C.
Thanks.
jimjutte
Post by jimjutte » Sun Mar 01, 2009 3:51 pm
Are you using Korean fonts with any other applications? Are you seeing this with any of them? I am just trying to rule out the operating system as part of the problem for the experts when they return on Monday. :)
Cheers
Jim
sphinx32
Post by sphinx32 » Mon Mar 02, 2009 12:30 am
Yes, I'm using Korean font with Korean IME (called diopen), and other application, (e.g., pocket word) has no problem at all.
If you would like to test with Korean font (diopen), I can send it to you for test.
Textmaker 2006 also having some other issue. This version is not allow typing Korean charactor at all. It is Okay for typing English.
Thanks for your support. :wink:
sphinx32
Post by sphinx32 » Mon Mar 02, 2009 12:32 am
Yes, I'm using Korean font with Korean IME (called diopen), and another application, (e.g., pocket word) has no problem at all. If you would like to test with Korean font (diopen), I can send it to you for test.
I also have tried Textmaker 2006 windows CE visrion on my MobilePro 900C, and also having some other issue. This version is not allow typing Korean charactor at all. It is Okay for typing English.
jimjutte
Post by jimjutte » Mon Mar 02, 2009 3:09 am
Okay. Sven (from SoftMaker) will likely either answer you in a few hours or send it to the technical folks as a question.
Cheers
Jim
Post by sven-l » Mon Mar 02, 2009 9:38 am
I referred that problem to our developers to check this and will inform you here as soon as we have more information.
Return to “TextMaker 2008 for Windows CE”
