Pivot Tables
Post bug reports and suggestions for PlanMaker 2008 for Pocket PCs.
Nigel
Pivot Tables
Post by Nigel » Mon Oct 20, 2008 5:14 pm
Is there any way that a cross tabulation (contingency table, if you prefer) can be created in PlanMaker? I guess Pivot Tables would be top of my wish-list but the ability to produce a cross tabulation would be good enough. I could see how to create it if macros were available but as it is, I think it has beaten me!
regards
Nigel
Re: Pivot Tables
Post by sven-l » Tue Oct 21, 2008 9:17 am
Hello,
Pivot tables and cross tabulation are already on our wishlist for upcoming versions but are not implemented yet and Macros are not supported by the Windows Mobile OS (missing OLE automation).
IAVA
Re: Pivot Tables
Post by IAVA » Wed Jan 28, 2009 10:06 pm
Hi.
I'm thinking to buy the software, but I like to read in pocket pc ready files with pivot tables.
Is that possile?
Regards
Re: Pivot Tables
Post by sven-l » Thu Jan 29, 2009 9:26 am
Hello,
SoftMaker Office dows not provide pivot tables but it should be possible to open files that contains pivot tables with PlanMaker on a Pocket PC.
If you want you can test it with our trial version:
http://www.softmaker.com/english/ofpdemo_en.htm
IAVA
Re: Pivot Tables
Post by IAVA » Thu Jan 29, 2009 12:06 pm
THNKS FOR TH QUICK REPLY.
I ALREADY USED TODAY THE TRIAL IN MY POCKET PC
IT OPENS THE FILES WITH PIVOT TABLE, BUT IT'S JUST SHOW IT. YOU CANNOT SELECT THE OPTIONS OF PIVOT TABLES O SEE THER DATA.
BY THE WAY WHEN THE PLANMAKER OPENS THE FILE GIVE ME THE MESAGE THAT CANNOT SEETHE MCROS OF THE PIVOT TABLE.
IT GIVE ME THE MESSAGE "SOME FORMULA COULD NOT BE LOADED. SWITCH ON SYNTAX HIGHLIGHTING TO CHECK WHICH CELLS ARE AFFETED. THESE CELLS WILL HAVE A COLOURED BACKGROUND".
Return to “PlanMaker 2008 for Pocket PCs”
