Errors on Samsung SGH i780
Post bug reports and suggestions for the PlanMaker 2008 for Pocket PCs beta software.
igalan
Post by igalan » Tue Apr 08, 2008 5:11 pm
A few days ago I received this phone which will replace my N560 + Touch for work use. So the first thing that I did was install Softmaker Office 2008 beta (the latest as of now) and see how it works.
First the dialog where you fill your personal and work data doesn't fit the screen properly, the text boxes are longer than the screen. Anyway it was possible to input the data. But as soon as I started typing with the hardware keyboard an error message popped up asking me if I wanted to send the report. Once sent PlanMaker was still there waiting for the data, so I just typed the rest of the information. This happened a few more times when using the hardware keyboard. TextMaker doesn't seem to suffer from this problem or not that often at least. This error happens always when I start typing data on a cell, even using the on screen keyboard. If I click on the input box before typing, there won't be any error.
Also the screen resolution seems to cause some small problems with configuration dialogs; it seems as if some controls are just out of the sceen so I can't reach them. As this device uses a screen resolution of 320x320, I guess that some adjustments need to be done. I will post screenshots as soon as I install some program for this purpose.
BTW, with PlanMaker I can use the hardware keyboard to enter letters with accents like á, é, etc. But with TextMaker this doesn't work, I get "àá" when I type [a] , [accent key] , [accent key], instead of "á".
HTC Desire S, F-S Loox N560
Re: Errors on Samsung SGH i780
Post by sven-l » Wed Apr 09, 2008 12:10 pm
Hello,
we´ve forwarded your request to the developers team and will inform you as soon as we have more information about it.
igalan
Post by igalan » Wed Apr 09, 2008 9:50 pm
Here are some screenshots.
Is there some checkbox just below the bottom border?
Dialog not properly scaled for 320 x 320
Post by sven-l » Thu Apr 10, 2008 8:37 am
igalan wrote:Here are some screenshots.
Thank you! We´ve forwarded the Screenshots to the developers.
Post by sven-l » Wed Apr 23, 2008 1:17 pm
Hello,
the problems are fixed now and won´t occur after the release of the next beta.
igalan
Post by igalan » Wed Apr 23, 2008 1:28 pm
Thanks I will post back when the new beta is made available.
igalan
Post by igalan » Thu May 08, 2008 1:02 pm
All the problems that I reported seem fixed on the revision 488 :) .
Return to “PlanMaker 2008 for Pocket PCs BETA”
