full VGA support (all apps)
Post bug reports and suggestions for the PlanMaker 2008 for Pocket PCs beta software.
massamino
Post by massamino » Sun Apr 06, 2008 11:45 am
Hello, nice work on the suite.
What I would like to see is full VGA support for the themes (vista, xp, linux, ...)
Maybe the cells in planmaker a little smaller when using a vga device. I always zoom to 75 or 50 percent to work in it (columnheaders and rowheaders also a little smaller?)
Regards
amuehl
Re: full VGA support (all apps)
Post by amuehl » Mon Apr 07, 2008 2:03 pm
Hello,
VGA support for Pocket PCs is already implemented in our software. Or what do you exactly mean with "full VGA support"?
Alexander Mühl
ealvarado
Post by ealvarado » Tue Apr 15, 2008 9:06 am
Hi.
I use the beta version on a X7501, it has a 5" screen using Real VGA in 96 DPI, and all looks great.
I attach a screen capture of the screen of my HTC, with all the bar displayed, and some text in the cell, The Zoom is 100%. Just Remember that I use Real VGA in 96DPI so, my screen may display more that in 192DPI.
Regards.
PlanMaker Screen in X7501
Post by sven-l » Tue Apr 15, 2008 10:41 am
ealvarado wrote:Hi.
Regards.
Hello,
we´ve forwarded your request for a support of 192DPI to the developers and will inform you as soon as we have any information about it.
ealvarado
Post by ealvarado » Sat Apr 19, 2008 9:26 pm
Hi.
I attach a screen captures for the planmaker using 192 DPI in my device a HTC X7501 (5" screen).
As you can see in a VGA device the cell and header appears bigger. It is one of the reasons I use Real VGA in 96 DPI, as show in a picture in the previous post.
As massamino said, the dimensions of the bars, cells and header could be define by user.
Regards.
PlanMaker Screen in X7501 192 DPI with only one bar visible
PlanMaker Screen in X7501 192 DPI with all bars visible
Return to “PlanMaker 2008 for Pocket PCs BETA”
