Trouble with TenGO
Post bug reports and suggestions for the TextMaker 2008 for Pocket PCs beta software.
DavyR
Trouble with TenGO
Post by DavyR » Mon May 05, 2008 12:08 pm
I am using an ipaq210, WM6. My licensed version of TextMaker worked fine with TenGo but I am encountering a major problem with the 2008 beta--when I select a word from the suggested list, the ipaq locks up completely and needs a soft reset. Using the WM keyboards is no problem. The lockup happens everytime I try to select a TenGO-suggested word; otherwise the two programs work fine.
Re: Trouble with TenGO
Post by sven-l » Mon May 05, 2008 12:15 pm
Hello,
what version of TextMaker 2008 for Pocket PCs do you use? Is it the new revision 488?
You can download the newest Beat here:
http://www.softmaker.com/english/ofp08_en.htm
DavyR
Post by DavyR » Mon May 05, 2008 1:43 pm
Yes, it is build 488.
Post by sven-l » Mon May 05, 2008 1:54 pm
We don´t have this problem with a DELL AXIM X51V.
Does a new installation of the Beta solve this problem?
schild
Post by schild » Mon May 05, 2008 2:01 pm
I'm using Tengo on my AT&T Tilt and I don't have any problem when I select a word from the suggestion list.
DavyR
Post by DavyR » Tue May 06, 2008 1:47 pm
I uninstalled from the SD card, redonwloaded and installed to memory and I now have the problem with the regular keyboard as well as Tengo, and am receiving "TextMaker has encountered a problem..." errors. I re-read your info page and I'm not sure I have one of the two CPUs you list. I am using the HP ipaq 210 Enterprise edition. That may be the problem???
Unless I can help you further in some way, I think I am going back to the licensed version I purchased earlier. I'll miss the direct printing but I can live with that.
Post by sven-l » Tue May 06, 2008 3:34 pm
Hello,
I´ve referred your problem to our developers and will report you as soon as I have more information.
Return to “TextMaker 2008 for Pocket PCs BETA”
