Uninstall from iPAQ PocketPC
Post bug reports and suggestions for the TextMaker 2008 for Pocket PCs beta software.
Fredk
Post by Fredk » Fri May 02, 2008 3:48 pm
I have installed Softmaker Office 2008 BETA on my iPAQ Pocket PC - installing it on the SD card.
I cannot see how to uninstall it - since it is not listed in the window where installed progam can normally be uninstalled.
Please advise.
Re: Uninstall from iPAQ PocketPC
Post by sven-l » Fri May 02, 2008 4:12 pm
Hello,
please connect your Pocket PC with your Desktop PC, look in the control panel on your Desktop PC and open "Add or Remove Programs". Select the SoftMaker Office and click on "Remove" and follow the instructions.
Fredk
Post by Fredk » Fri May 02, 2008 6:06 pm
Thank you! So simple! Why didn't I think of that!
DrAT
Post by DrAT » Sun May 18, 2008 1:26 pm
Fredk wrote:Thank you! So simple! Why didn't I think of that!
Well, it's not how most PPC programs are removed after all.
Anyway, why would you want to remove such an amazing application :D
WM2003SE - HP iPAQ hx4700 - 64Mb RAM
WM5 - XDA Mini S
WM6 - HP iPAQ 214 - 128Mb RAM
WM6.5 - HTC HD2 - 448Mb RAM
StowAway BT Keyboard
Return to “TextMaker 2008 for Pocket PCs BETA”
