Manual zoom level dialog not working
Post bug reports and suggestions for the TextMaker 2008 for Pocket PCs beta software.
Robrecht
Postby Robrecht » Fri Mar 14, 2008 1:49 am
The manual zoom level dialog (where you can enter a custom percentage instead of the presets) does not appear when you select it from the taskbar or the menu.
HTC Desire HD
amuehl
Re: Manual zoom level dialog not working
Postby amuehl » Fri Mar 14, 2008 10:10 am
Hello,
yes, this is reproduceable for me. I've forwarded a bug report to our developers.
Alexander Mühl
gurachn
Postby gurachn » Thu Mar 27, 2008 4:39 am
I was just about to note the same issue.
When you are correcting this issue would it be possible to set it so that the custom zoom you select becomes the default?
amuehl
Postby amuehl » Thu Mar 27, 2008 12:23 pm
gurachn wrote:When you are correcting this issue would it be possible to set it so that the custom zoom you select becomes the default?
Just edit the default template (normal.tmv), set the desired zoom level and save the file. If you now open a blank document (File => New), the new zoom level will be default.
Alexander Mühl
gurachn
Postby gurachn » Thu Mar 27, 2008 1:41 pm
Thanks for the reply, however, I cant get the custom zoom to work right now.
Where is the default location of the Normal.tmv?
amuehl
Postby amuehl » Thu Mar 27, 2008 3:28 pm
gurachn wrote:Thanks for the reply, however, I cant get the custom zoom to work right now.
This will be fixed in the next beta version.
My Documents\SoftMaker\Templates
Alexander Mühl
gurachn
Postby gurachn » Thu Mar 27, 2008 3:48 pm
Great
Looking forward to the next version
Return to “TextMaker 2008 for Pocket PCs BETA”
Who is online
