Printing
Post bug reports and suggestions for the TextMaker 2008 for Pocket PCs beta software.
DrAT
Printing
Post by DrAT » Tue Mar 04, 2008 8:11 am
It's great to be able to print documents, formatted how they should be, from a Pocket PC. I couldn't do this before; much of the layout was lost.
I've experimented with a WM2003 device and this is how I print at the moment.
My printers don't like Postscript so direct printing doesn't work, though my PPC does send something to the printers. The latest version of JetCet doesn't work with WM203SE devices either, and older versions aren't called by TM.
The workaround I use is to save the file as a PDF and to open and print it from Westek ClearVue PDF. Memory is in short supply on 64Mb devices, especially with BlueTooth running, and large documents fail because of this, but otherwise, it works well. The old version of ClearVue Document discarded some formatting when printing but CVPDF doesn't.
Would it be possible to make the application TM opens to print PDFs an option? It would add convenience for users of older devices. It would, though, make the shortage of memory more acute on devices wth little memory.
More printer languages would be nice too. Mine uses PCL, I think, but again, any changes like this would eat memory.
It's good to print ;-)
WM2003SE - HP iPAQ hx4700 - 64Mb RAM
WM5 - XDA Mini S
WM6 - HP iPAQ 214 - 128Mb RAM
WM6.5 - HTC HD2 - 448Mb RAM
StowAway BT Keyboard
hops
Re: Printing
Post by hops » Tue Mar 04, 2008 10:43 pm
that has worked for me also, and saving as a pdf can print with PrintBoy also.
DrAT
Re: Printing
Post by DrAT » Wed Mar 05, 2008 4:17 am
hops wrote:...a pdf can print with PrintBoy also.
That's good to know. I'm due a free copy that was bundled with my portable printer. I'm waiting for the serial.
WM5 - XDA Mini S
amuehl
Re: Printing
Post by amuehl » Wed Mar 05, 2008 12:31 pm
Hello,
DrAT wrote:More printer languages would be nice too. Mine uses PCL, I think, but again, any changes like this would eat memory. It's good to print ;-)
we are sorry, but at this point there are no plans to add more printer languages.
Alexander Mühl
schild
Re: Printing
Post by schild » Fri Mar 07, 2008 7:44 pm
I also like the printing. I'm using JETCET on a WM6 device (AT&T Tilt) printing to an HP L7780 All-In-One.
Return to “TextMaker 2008 for Pocket PCs BETA”
